Fix serial chart performance in dashboards for high feature counts
1272
08-27-2025 10:53 PM
Status: Open
GraceUziallo
Recent updates to dashboards in AGOL and In Enterprise 11.5 have seriously impacted the performance of any dashboard displaying many features in a serial chart. The changes are detailed in this blog post Charts in Dashboards: What’s coming for AGOL last year and as can be seen in the comments below that quite a few people have been negatively impacted. We have built highly customised dashboards for users to view timeseries data for things such as water quality monitoring. Prior to the 11.5 upgrade, these all performed well, but since then they have been terrible. Even when the data has been thinned out to <1000 features, what used to load instantly now takes users 20 seconds+ to view. As spatial professionals, we have to build trust with our users, stuff like this erodes all that. In the blog post about these changes for AGOL, Esri recognised that this would cause slowdowns for feature heavy serial charts - but argued the changes would overall be better. That's all well and good if the change was well documented and clearly communicated to users well in advance - alas this has not occurred (the new 10k feature limit is nowhere to be seen in documentation), and we are left scrambling to try and salvage these important dashboards for increasingly frustrated users.
3 Comments
MartaZ
We have the same problem in our company. Dashboards which were working totally fine in Portal 11.3, now in 11.5 barely respond, hang and are useless. Our company will most probably be switching from ArcGIS Dashbords to Microsoft Power BI to create operational panels for bigger datasets.
There are two BUGs for serial chart slowness:
- ArcGIS Online: BUG-000177827 for ArcGIS Dashboards
- ArcGIS Enteprise 11.5: BUG-000181698  (this BUG has been created from my support case and it is not yet available to everyone)
Unfortunately the ArcGIS Online BUG is classified as "known limitation outside of Esri's control", so Esri will probably not fix it. Anyway, if other people see performance issues with serial charts in Portal 11.5 or ArcGIS Online I would suggest contacting Esri Support and subscribing to the proper BUG.
YEL
Hi, we are experiencing the same issue with ArcGis Dashboard in Enterprise version 11.5.
That is, performance degradation and very slow rendering after a short while of user operational use experience.
Only After refreshing the browser the application become stable and fast again.
Have someone managed to overcome the issue that seems to be a client application side management problem?
Cheers
MHami
We're experiencing the same issue after an upgrade.  My hope for organizational use of dashboards has evaporated along with the good performance we had.  No fix besides restructuring our dataset which is a major task.
