Enable data download in dashboard table when table type is "features" and data source is a data expression
4928
13
01-30-2024 08:31 AM
Status: Open
erica_poisson
Enable export/download consistently within Dashboards. The example below is specifically when a Data Expression is used with the Table Element of a Dashboard.
Data export/download currently works if you are referencing a hosted feature layer as the data source, OR if you use a data expression as the data source and select Table type = Grouped values. Data export/download does not work if you data source is a data expression and you select Table Type = Features.
I've tested this with the same data expression. The data sources used within the expression all have the export capability enabled via the Item Details.
Here is the data expression:
// custom memorize function to increase performance of featureset
function Memorize(fs) {
    var temp_dict = {
        fields: Schema(fs)['fields'],
        geometryType: Schema(fs).geometryType,
        features: []
    for (var f in fs) {
        var attrs = {}
        for (var attr in f) {
            attrs[attr] = Iif(TypeOf(f[attr]) == 'Date', Number(f[attr]), f[attr])
        Push(
            temp_dict['features'],
            {attributes: attrs, geometry: Geometry(f)}
    return FeatureSet(Text(temp_dict))
// variable to define the portal URL
var portal = Portal("https://mass-eoeea.maps.arcgis.com");
//Quabbin and Ware Encroachments - internally shared layer w/ export enabled
var qEncroach = FeatureSetByPortalItem(portal,"1234abc",0,['Date_Found', 'Type', 'Encroachment_Priority', 'Description'],true);
//Wachusett and Sudbury Encroachments - internally shared layer w/ export enabled
var wEncroach = FeatureSetByPortalItem(portal,"5678def",0,['Date_Found', 'Type', 'Encroachment_Priority', 'Description'],true);
// Create a FeatureSet with all encroachments from Quabbin, Ware and Wachusett
var int_dict = {
    fields: [
        {'name': 'type', 'type': 'esriFieldTypeString'},
        {'name': 'edate', 'type': 'esriFieldTypeDate'},
        {'name': 'priority', 'type': 'esriFieldTypeString'},
        {'name': 'descript', 'type': 'esriFieldTypeString'}],
    geometryType: 'esriGeometryPoint',
    "spatialReference": {
        "wkid": 102100,
        "latestWkid": 3857
    }, 'features':[],
// Fill intermediate FeatureSet with encroachment info
var i = 0;
for (var f in qEncroach) {
    int_dict.features[i] = {
       attributes: {
         'type': f["Type"],
         'edate': DateDiff(f["Date_Found"], Date(1970, 0, 1, 0, 0, 0), "milliseconds"),
         'priority': f["Encroachment_Priority"],
         'descript': f["Description"],
       geometry: Geometry(f),
     i++;
for (var g in wEncroach) {
       attributes: {
         'type': g["Type"],
         'edate': DateDiff(g["Date_Found"], Date(1970, 0, 1, 0, 0, 0), "milliseconds"),
         'priority': g["Encroachment_Priority"],
         'descript': g["Description"],
       geometry: Geometry(g),
     i++;
Console(Text(int_dict));
var encroach_set = Memorize(FeatureSet(Text(int_dict)))
// Basins - public layer
var basins = Memorize(FeatureSetByPortalItem(portal, "987406d7d0614370b6493dfe58c9e62c", 0, ['District', 'Subbasin_Name'], true))
// create final featureset
var finalDict = {
  fields: [
    {name: "Encroach_Type", type: "esriFieldTypeString"},
    {name: "Encroach_Date", type: "esriFieldTypeDate"},
    {name: "Encroach_Priority", type: "esriFieldTypeString"},
    {name: "Encroach_Description", type: "esriFieldTypeString"},
    {name: "SubbasinName", type: "esriFieldTypeString"},
    {name: "DistrictName", type: "esriFieldTypeString"},
  geometryType:"esriGeometryPoint",
    "wkid":102100,
    "latestWkid":3857
  features: [],
// intersect CMRs with basins to determine which basin each occured in
for(var e in encroach_set) {
  var i_basin = First(Intersects(e, basins))
  var i_basin_name = Iif(i_basin == null, "No basin", i_basin.Subbasin_Name)
  var i_basin_district = Iif(i_basin == null, "No district", i_basin.District)
  //add to array
  Push(finalDict['features'],
  {attributes:{
    Encroach_Type: e['type'],
    Encroach_Date: e['edate'],
    Encroach_Priority: e['priority'],
    Encroach_Description: e['descript'],
    SubbasinName: i_basin_name,
    DistrictName: i_basin_district,
Console(Text(finalDict));
return FeatureSet(Text(finalDict))
Here are the settings used within the Table Element when download summarized data is an option for me to toggle under "General":
Here are the settings used with a different Table Element when download summarized data is not an option for me to toggle under "General":
Some additional details:
I am working in ArcGIS Online and using a data expression to bring two different feature layers together into a new FeatureSet. I need to provide information on individual records, so I can not use Table Type = Grouped Values. Both feature layers referenced in the data expression allow export/download (that was the first thing I checked).
13 Comments
MTracy1
@ReubenWolff I tried your json edit solution and it works. Thank you for sharing!
Still would be nice to have this as a built-in dashboard capability.
NICK_COG
I have lots of Survey123 forms that are then aggregated and have various cleaning operations performed on them with a data expression. It would be great if these could be downloaded as spreadsheets.
We are using it to get a CSV that can be sent to a vendor for easily updating out of stock inventory items.
HollyTorpey_LSA
@ReubenWolff Thanks for sharing your solution! It worked for me.
