Dynamic extent in dashboard
845
02-21-2020 07:21 AM
Status: Open
MelanieWawryk
It would be nice to be able to have the default extent in dashboard be dynamic based on feature layer. This way the initial extent of the map would be focused on the current features you want to highlight in the dashboard. For example in a dashboard for road closures instead of using the extent of the map used in the dashboard, you could instead select a layer in the map setting within dashboard and it would zoom to the current road closures. There should be a new tab for map extent that allows you to select the layer and a % zoom. That way as the data changes the initial extent of the map would relfect those changes.
