Dashboard template
1201
08-08-2022 03:17 AM
Status: Implemented
Hala_Ghareeb
I wonder if it is possible to save a dashboard template to be used with other maps and to be able to share this template with colleagues.
Tags (1)
3 Comments
rsun_TQB
Hi @Hala_Ghareeb ,
Maybe create a dashboard called "XXX Template" and design the outline of your dashboard. Then, you can use "Save As" to generate a new dashboard every time you need it? Or I will use other existing dashboard with "Save As".
May not be ideal, and you may still not have permission to share with your colleagues.
Regards,
Reno
SteveF
I agree, the ability to save an existing dashboard with a new map is a must.
SandraLuken1
With the October 2025 release of ArcGIS Dashboards, the ability to swap data sources is now available through the new data sources panel
See the related blog post here
