Dashboard printing funktion
755
04-22-2024 01:37 AM
AnnelieSköld
In ArcGIS Dashboard on some of the elements you can activate the funktion "Summarized data download". This can be used for example in bar charts, but only if the data is grouped. I would like to have a similar funktion on all of the different types of elements. If this isn't possible I want to be able to print out the information instead so I can save and compare the statistics or information from different periods of time. For example I have imported information about different companies which is presented in my dashboard as a list. The information is updated and overwritten every day and always present fresh data which is awsome. But sometimes I would like to make a printout or be able to download data so I can save the result and compare it to older lists/information.
/ Annelie Sköld, Sweden
2 Comments
MartinCopping
ThijsBriggeman_Tensing
Amen to that! I would like to be able to print out the statistics from a dashboard to .pdf. I hear this wish from customers a lot! Now I have to re-create a dashboard in Experience Builder (which is way less intuitive and not to 100% the same as an ArcGIS Dashboard) in order to print a map.
