Calculate widget based on other widget values
829
03-10-2021 10:03 PM
Status: Open
Michael_Kraus
I have a point layer and a polygon layer both independently managed.
Eg: point layer of pizza shops and polygon census tracts showing number of college students
I can have an indicator widget showing the number of pizza shops in the map extent
I can have an indicator widget showing the number of college students in the map extent
What I want is for one widget to be able to refer to the other and display a rate / ratio etc.  Just take two numbers that ArcGIS has displayed on the screen and perform a simple calculation.
A pre-process / data process isn't valid here, as this needs to change with the map extent and pre-calculating a value (eg: pre-calculated pizza shops per census tract) the widget can only display a raw average and this is quite misleading, so doesn't work.
I can't see this in the new or old Dashboards.  Would be great to know if there is a way to do this or if it is in the pipeline.
