Adding an 'onload' or 'init' Action for Operations Dashboard Widgets
1472
07-12-2018 11:40 AM
Status: Implemented
MaikFlanagin
If I have a list that I use to filter the map and charts, I would like to be able to define the behavior when the application is first loaded, before an item in the list is selected. Specifically, I would like to remove all data from the chart if no item in the list is selected. I believe this could be accomplished by the addition of a new Action type for when the page is loaded or widget is initialized.
2 Comments
patrickb
We are working on something like this, and it should be available to try when the next refresh of ArcGIS Dashboards Beta is made available (hopefully early 2021).  We're currently referring to this new feature as 'conditional rendering', and it is tied to our actions framework.
patrickb
In the April 2021 release of ArcGIS Dashboards, we added a 'render when filtered' option to element/action configuration.
https://doc.arcgis.com/en/dashboards/reference/previous-releases.htm#ESRI_SECTION1_94E422EE26D442E2A...
