Add URL of map to Map Settings
5454
07-22-2022 12:07 PM
Status: Open
ChristineCarrelli1
New Contributor II
We often need to edit the map used in a dashboard to update symbology, configure popups etc., however, when you are editing the dashboard you cannot see the source URL for the map so you don't necessarily know what map to edit to make the required changes.  You end up having to search your content and guess which map is being used to update it.
Please add the URL, or even just the name of the map to the settings for the map in the dashboard.  The General tab might be the best place to put it.  There is a 'Name' field in the General tab, but it is the name of the element, not the name of the map itself.
1 Comment
SteliosPhilippou
This would be very helpful indeed !
