Unable to retrieve feature layers when setting up ArcGIS Connector in Microsoft Power Automate
12594
29
08-06-2022 10:25 AM
KevinMantels
I am trying to create a new automated cloud flow in Microsoft Power Automate using the ArcGIS for Power Automate connector and its available triggers.  Regardless of which trigger I use, when I attempt to select the feature layer to be tracked I receive the following error message: "Could not retrieve values.  The dynamic invocation request failed with error: Unexpected error occurred when calling the APIHubsRuntime API: ...".  A screenshot of the error message is below.
I have confirmed that the ArcGIS for Power Automate connector has the correct credentials for my ArcGIS Online account and is connected.  I have a premium Power Automate account, so even though ArcGIS is a premium connector I do not believe that would be the issue.  I am using Power Automate in a government environment, and I have noticed that the connectors that are available in my government account are limited compared to those available in commercial accounts, but I am uncertain if that could be causing these issues.  Lastly, for what it's worth, I am able to create flows with the Survey123 connector without any issue.  I realize they are two completely different connectors, but I am still mentioning in case it is relevant.
I am not sure if I am missing some steps or settings.  The Survey123 connector worked out of the box, so I had assumed the ArcGIS connector would as well.  Bottom line is I am out of troubleshooting ideas at this point.  Any assistance would be greatly appreciated.
Jamie_Leitch_CNF
Hi @NataliyaLys , Are you seeing any errors?  My ArcGIS Get data from feature layer step in my flow times out after 7 retries with GatewayTimeout errors.
NataliyaLys
@Jamie_Leitch_CNF  When I click on ArcGIS Connection details this is an error that I see: Failed to refresh access token for service: oauth2generic. Correlation Id=060bdd10-4b4e-1d38-dc39-ab2040cfae25, UTC TimeStamp=6/9/2025 7:59:10 PM, Error: OAuth 2 access token refresh failed. Access token request to https://unitedstates-002.azure-apim.net/proxy/api/authentication/oauth2/token failed. Client ID and secret sent in form body. Details: A task was canceled.. Response status code=InternalServerError. Response body:
If I click 'Reconnect' it appears to reestablish connection, but my flows still fail. And if I try to fix connection within a flow it just spins and it never gives me a list of feature services from my content.
Jamie_Leitch_CNF
@NataliyaLys I'm seeing the same.  Also when I go to the Connections page in Power Automate, I see this:
And when I click Reconnect, a window pops up and appears to sign into AGOL again and in shows "Connected" on the connections page.  The page will shows "Reconnect" again if I refresh it after a while.
ArcGIS Online health dashboard shows no issues and MS Power Platform shows no issues either.
AkshayHarshe
Hi @Jamie_Leitch_CNF There has been an issue with the ArcGIS for Power automate containers since this morning, we are working hard to get to the bottom of the issue. We are sorry for the inconvenience this has caused.
Akshay Harshe
Jamie_Leitch_CNF
@AkshayHarshe  I just did a test with one of my flows and it seems the issue is resolved - thanks!
CORFOPYM_Ingenieria
I have the same problem, please help.
Jamie_Leitch_CNF
@CORFOPYM_Ingenieria  try testing it today, I believe they fixed this.
CORFOPYM_Ingenieria
Thanks, it's working now
Jamie_Leitch_CNF
I created a flow in MS Power Automate to hopefully mitigate any more issues with this.  Here is what I did.
  1. Create a cloud flow that is triggered by Recurrence and set it to run daily.
  2. Add a step for ArcGIS - Get data from feature layer.
  3. Choose a feature layer from your content that will never be removed.
  4. Add a Scope Control action and configure the Run after settings to be: has failed, is skipped, has timed out.
  5. In that Scope Control add a "Send email" action to email yourself.  This way, if the connection to ArcGIS times out or fails, you will get an email.  When successful, this shoulda also update the security token for the ArcGIS Connectio.
hopefully this helps
DaveAlmond
I was having the issue where the 'Layers in' layer list would not dynamically populate and the connector (ArcGIS Enterprise, Create a record in a feature layer) would raise the 'Could not retrieve values' error + the stack trace. Instead of selecting 'My Contents/My Groups/My Organization' for the 'Layers in' parameter, I favorited the target layer in Portal->My Content and chose 'My Favorites' for the 'Layers in' parameter, which solved the issue of connecting to a multi-layer feature service for me.
Initially, the 'Create record in a feature layer' action only allowed me to enter the Item ID of the target layer since the dynamic layer-picker would not load (and raised the 'Could not retrieve...' error). Entering the Item ID as a custom value in the Feature Layer parameter would show me the correct feature layer's attribute fields (in a two-layer feature service), but the flow failed and raised the error that the Layer ID was not passed to the request. Once I set the 'Layers in'  parameter to Favorites, the connector distinguished between Layer 0 and Layer 1 in the request, which solved my issue.
