I am trying to create a new automated cloud flow in Microsoft Power Automate using the ArcGIS for Power Automate connector and its available triggers. Regardless of which trigger I use, when I attempt to select the feature layer to be tracked I receive the following error message: "Could not retrieve values. The dynamic invocation request failed with error: Unexpected error occurred when calling the APIHubsRuntime API: ...". A screenshot of the error message is below.
I have confirmed that the ArcGIS for Power Automate connector has the correct credentials for my ArcGIS Online account and is connected. I have a premium Power Automate account, so even though ArcGIS is a premium connector I do not believe that would be the issue. I am using Power Automate in a government environment, and I have noticed that the connectors that are available in my government account are limited compared to those available in commercial accounts, but I am uncertain if that could be causing these issues. Lastly, for what it's worth, I am able to create flows with the Survey123 connector without any issue. I realize they are two completely different connectors, but I am still mentioning in case it is relevant.
I am not sure if I am missing some steps or settings. The Survey123 connector worked out of the box, so I had assumed the ArcGIS connector would as well. Bottom line is I am out of troubleshooting ideas at this point. Any assistance would be greatly appreciated.
