The dynamic invocation request failed
6248
07-05-2023 07:47 AM
by Anonymous User
Not applicable
Hi
When attempting to set up a Flow I'm getting the following error. Same if its a Trigger or an Event. I've tried to check my login to Power Automate and my ArcGIS Online are correct but I'm missing something. Can anyone advise?
Could not retrieve values. The dynamic invocation request failed with error: { "error": { "code": 400, "source": "europe-001.azure-apim.net", "clientRequestId": "16337903-53c6-4ef8-9310-7f549ade3907", "message": "The response is not in a JSON format.", "innerError": "Missing token or incorrect login credentials.Check your connection and credentials and try again." } }.
AlagiriVenkatachal
Hello Eamonn,
Can you provide a screenshot of your flow?
Also, could you please delete (in Power Automate, from "Data" > "Connections"). If there are multiple connections to ArcGIS connector, try to delete them all and create a new connection and see if that addresses this issue.
Alagiri
JesseCloutier
Esri Community Manager
For record keeping: Original post author is @EamonnDoyle
Jesse Cloutier
Community Manager, Engagement & Content
EamonnDoyle
Thank you @AlagiriVenkatachal I tried your suggestion but to no avail. I have moved my Flow to an alternative ArcGIS Online Subscription and am no longer experiencing the issue raised. ~ Eamonn
