Duplication when using "Fetch updates, changes, or deletions from feature layer" with feature layer views
1333
03-11-2025 11:13 AM
AnthonyJonesRSK
This may be quite a niche one but hoping someone can assist. I'm using survey123 to capture data and I have two versions of my form, one for regular users and one for managers. The manager one has full access to the dataset and the user one utilises a view that doesn't allow editing of other users data.
I have two flows set up so that when either of these forms are used they check for new entries to the underlying dataset or view and then create a task in Microsoft planner. The trigger I'm using is "When a record is created in a feature layer" and then I'm using "Fetch updates, changes, or deletions from feature layer" to get the details to use to create the planner entry. As far as I could tell I needed two flows as the trigger has to be against the layer that is edited (even if it is a view).
The issue I'm having is that my flows are creating duplicate entries in the planner. The issue seems to be that if a user uses one version of the form and creates a new entry that runs fine. But then if another user uses the other version of the form then "Fetch updates, changes, or deletions from feature layer" pulls not just the new entry that triggered the flow but those from when the dataset was updated from the other survey too. So one new entry may have been created in the form but previous entries created when the other form was run are included in the outputs.
Is there any way to prevent this? Ideally I want "Fetch updates, changes, or deletions from feature layer" to only process the changes that triggered the flow. Is there any way to limit this?
Any assistance on this would be much appreciated.
Anthony
MeganHicks
Hi Anthony,
It seems to me that you would only need to set up one flow that triggers when the underlying data is updated. If a user updates the View, it will still update the underlying data. So you would only need one flow to watch the underlying data and trigger the change to Planner.
AnthonyJonesRSK
Hi Megan,
Thanks for your response. The issue is that I think the flow won't trigger if it's configured with the underlying layer in the trigger but it is the view that you edit. I believe your trigger needs to use the layer or view that is actually edited to work. I'll have to double check again but pretty sure that's the case.
Cheers
Anthony
