I am creating this post to ensure everyone stays informed about the issue we discovered with the "When a survey response is submitted" trigger. Please note that this is still under investigation so there could be discrepancies or updates to the following information.
This issue affects All connectors: ArcGIS, ArcGIS Enterprise, Survey 123
When we create a flow using the "When a survey response is submitted" trigger in Power Automate, it generates a webhook in the Survey123 App. Currently, the webhook is created with the default name MS-FLOW, whereas previously it was named MicrosoftPowerAutomate-[flowId]. When multiple flows are created for the same survey using this trigger in Power Automate, it fails to assigns unique names; instead, it replaces the existing webhook in the Survey123 app with the same MS-FLOW name.
After conducting some tests, we have identified the following findings. We know the this behavior is due to a recent change by Microsoft, as they are transitioning their URLs from "logic.azure.com" to a new architecture using "api.powerapps.com" where the URL construction is different than before causing internal failures. For reference, please see: Troubleshoot common issues with triggers - Power Automate | Microsoft Learn.
Unfortunately, we did not anticipate any issues with this change when we audited our code and it expressed itself in the Survey 123 app. We are working with Survey 123 team to investigate and resolve with best possible solution and as soon as possible. We apologize for any inconvenience. Please see following details and workaround.
Firstly, we think that Microsoft is still rolling this update and not everyone will experience this issue.
If you wish to create multiple flows on a single survey using `When a survey response is submitted` trigger then
Please be mindful when turning on an older flows on survey that has other active flows as it can replace an existing webhook on the survey if it is named "MS-FLOW"
Hope this helps.
