Zip code - Point comparisons in Community Analyst
3732
01-20-2012 03:28 AM
AndrewSchroeder
If I have a set of points and I want to know zip-code level reports for each point what do I have to do in Community Analyst to facilitate that as a batch run rather than a point-by-point manual operation?
Jason_RobinsonRobinson
Andrew,
Currently Community Analyst does have the functionality to identify the zip codes that your points fall into.  If you have ArcGIS 10 this could be done with a few steps.  If you do not I could probably provide you with a zip code shapefile that you could upload if you could provide me with your point info.  Don't mind doing this for user specific project work.
Regards,
Jason R.
Andrew,
Regards,
Jason R.
