Infographic for multiple polygons
2153
01-18-2023 09:47 AM
dalvarez
Good Afternoon!
I was tasked with running 3 infographics to each 45 different polygons that each represent a neighborhood. Is there a way to run an the tool to all 45 polygons (or multiple polygons) at the same time?
I went into the map, added the layer, get ready to run infographic, see image.
CherylHagevik
Hi @dalvarez, thank you for reaching out with your question. Using the Reports tab, you can export mulitple infographics at the same time and can run up to 100 infographics at once. Just go to Reports > Run infographics. For reference, here is the Run infographics help resource.
You will see an interface where you can select sites and infographics templates, then you can click Export All.
Please let me know if these details help to answer your question.
CherylHagevik
dalvarez
Thank you so much for the solution. I was able to run the infographic on 59 polygons. I was able to do it 10 polygons at the time for some reason, but I got what I need it.
again,
Thanks!!!
