Creating a thematic map
3939
01-13-2012 12:34 PM
HeatherHenderson
How can I create a thematic (color coded) map using data that is ALREADY in the map in Community Analyst?  I know I can do this using the color-coded map tab and then choose new variables but what about applying the color coding on variables that are already in my map?
BrendaWolfe
Hi Heather,
I am afraid I don't understand what you are asking.  What do you mean by data already on the map?  Are you referring to web maps you access from ArcGIS Online?
Brenda
Jason_RobinsonRobinson
Have you imported your own polygon data via shapefile?  Some clarification on what data is already in the map would help.
Regards,
Jason
