Coordinate System in Mexico
2219
03-17-2021 12:19 PM
bdaoust6
I need to analyze a dataset that covers the whole country of Mexico. In Oasis Montaj (Geosoft), I chose the Mexican Datum of 1993 as the geographic coordinate system, but I also need to use a projected coordinate system (in order to do the analysis, Oasis Montaj needs to have grid coordinates) and I'm not sure which one to use?
Thank you!
JayantaPoddar
MVP Alum
It would be wise to connect with Geosoft support for working on Oasis Montaj.
But let's assume you have the GIS Dataset in ArcMap/ArcGIS Pro. 😉
You may choose to convert it to
Projected Coordinate System: WGS_1984_Web_Mercator_Auxiliary_Sphere (WKID:3857)
Transformation Method: Mexican_Datum_1993_To_WGS_1984_1
Think Location
