sync issue for collector, server throwing a series of errors
5021
03-31-2016 09:50 AM
by Anonymous User
Not applicable
Any help would be great,
All issues are related to the System/SyncTools.GPServer
     Failed in acquiring Archive Difference Cursor for dataset: wmhb_gis.DBO.DispCampInventory_DP for Replica: DBO.Ags_Fs_1448316015807      [GUID: 5EC4984C-6AE5-47F3-BD31-E6AC8E5BB407]. Time taken: 0.049000 seconds. Underlying DBMS error      [WMHB_GIS.DBO.DISPCAMPINVENTORY_DP][STATE_ID = 2727]. Dataset: wmhb_gis.DBO.DispCampInventory_DP. Replica:      DBO.Ags_Fs_1448316015807.
RichardLawrence1
Has there been any insight on this?
Sent from my iPhone
MichaelDavis3
You might look into the available memory on your database server - we've found that when using archiving the server needs a ton of RAM to sync.  This is especially true if you are doing photo attachments.
MiaogengZhang
Are you running into similar issue like https://community.esri.com/message/378915?
GaryMacDougall
Hi
One thing to check out is the 10.3.1 sync patch:
ArcGIS 10.3.1 for (Desktop, Engine, Server) Feature Service Sync Performance Patch | Samples and Uti...
There is an item addressed in this patch that returns the same error message you list above.
thanks
Gary
