Should we use "for export" vector basemaps when authoring for offline Collector?
840
12-21-2018 01:16 PM
JakeJacobs
I see that there's a set of ESRI official vector basemaps that is specifically "for export" to take offline.  Is it recommended to use those when authoring a webmap that you plan to use offline in Collector?  I don't see them when I search the Living Atlas inside the web map "add item" but reading the summary of the item, it sounds like this would be preferred.  Since you have to have a basemap in your map, and since you can't yet indicate that you already have a basemap on the device you want to reference when creating an offline area (ad hoc or via web map), there is going to be a lot of basemap downloading going on.
I found them with the tag World_Basemap_Export_v2
https://www.arcgis.com/home/search.html?t=content&q=tags%3AWorld_Basemap_Export_v2&start=1&sortOrder...
