Secured service requires 3 sign ins?
6461
10
04-21-2015 02:54 PM
VenusScott
I'm already hearing squawking . . .
We have configured our AGOL account to use the Active Directory Federated Services. That being said why is it when I am using the Collector application I first have to log into our network via VPN (with AD credentials) then when I go to my tablet to view my maps I have to log into our AGOL portal (with AD credentials) and then if the map contains a secured service, I have to log in to access that secured service again with AD credentials?
Do I have something configured wrong? I thought the whole purpose of Active Directory Federated service was for "single" sign-in.
MiaogengZhang
Active Directory configuration is supported in ArcGIS Online. But when you sign in with your AD credentials in ArcGIS Online, those AD credentials won't be passed to ArcGIS Server (can't federate from ArcGIS Online to ArcGIS Server). Then you need to sign in twice to access secured service in ArcGIS Server. In Portal, once the server is federated, you will only sign in once.
