Popups and Editing
1611
04-24-2014 01:21 PM
LuciHawkins
We have a feature service layer that we uploaded and added to an Arcgis.com webmap.  Then we created a custom popup on our Arcgis.com map so that only the fields we want to edit would show up.  However, when we click "edit", ALL of the fields are visible and we have to scroll thru them to find the fields we want to edit.  Is there any way around this?
Luci
RussRoberts
Esri Notable Contributor
When you configure the attributes for the popup and you are using iOS you need to enable just the edit check boxes for it to show up in the editing popup.
Russ
RussRoberts
Russ
LuciHawkins
Thank you Russ!  The "Configure Attributes" should be a big button or something that stands out more, I never even thought to click on those words.
[ATTACH=CONFIG]33437[/ATTACH]
Luci
