Open txt in domain
1770
09-11-2014 11:20 PM
roialgavish
I have an "out of the box" question about ways of using the collector. I wonder is there a way to insert a txt into specific domain?
For example:
Let's say the domain is "my name is _____ and I am 12 years old"
And I want to insert in the blank place open txt or another domain like "Dani" or "Roi" or anything else.
Is there a way?
I know I can define a subtype but then I will get: in one field "my name is _____ and I am 12 years old" and the in the other field "Roi".
If there isn't a way I think it will be a nice upgrade.
Thank you,
Roi Algavish.
RussRoberts
Esri Notable Contributor
This is currently not supported. This would be changing a defined value set at the database level. If you are just using these values for display purpose you could adjust the popup in the web map. So what I would do is switch the popup from an attriubte list to a custom popup. This means you ca start writing the text for a sentence and then introduce fields within your sentence so when you identify a feature you will see the field values displayed within your sentence.
The popup configuration could look like this: my name is {NAME} and I am {AGE} years old
Russ
