Offline with local coordinate system
947
06-05-2014 06:47 AM
YigalMuntner
Hello All,
I want to go offline, with local TPK as basemap, and a hosted feature service in a local coordinate system (not Web Mercator).
I keep getting errors. The only way I can go offline is by converting all the data to web mercator.
Can the collector support such workflow?
Regards,
Yigal
RussRoberts
Esri Notable Contributor
What error are you seeing? Does the map go offline if you do not use your tpk?
Russ
