Offline multiple layers
11982
11
01-16-2015 02:33 PM
DougBrowning
MVP Esteemed Contributor
I have a map with about 15 layers on it that are all part of a single feature service.  All point to a single sql db.  I can see and edit all of them in a webmap no problem.
When I try to download the map in Collector I get this error
"The map failed to download with the message: Failed to create replica.  Multiple layers are referencing a dataset, which is not supported"
Also note the download stays in the android notification bar forever
Tried using ArcGIS Online and Portal 10.3 (and server 10.3).
I made a new map with just one of these layers and it works fine.  I am pointing to the exact same Feature Service just using a /10.
I can find nothing in the help or here on this.
I think it means I can only have one editable layer in a map when going offline.  But that seems strange.  Not a very useful app if I can only edit one thing.
Is there any documentation on this?  I would like to know how to work around it or what all my limits are.  Do I need to publish one layer per feature service (and if I do can I add multiple feature services to a map then download) or have one feature service and the rest map service?
HariharNepal
sounds like you downloaded the offline map with multiple layers on it, but when I do that, it only downloads the web feature layer, not even the hybrid reference layer. Is it possible to download the offline map with hybrid feature layer and with parcel boundary layer? Thank you.
DavidTreering1
This is broken again in Enterprise 11.5.
