Offline editor tracking
7589
16
05-01-2014 06:19 AM
CollinGrove1
When using editor tracking with a hosted feature service, connected edits record the username of the logged in user. However, in both Android and iOS Collector app versions (latest of each), the user name is not recorded, but the time is.
Has anybody else noticed this, and is there a fix in the works?
RussRoberts
Esri Notable Contributor
Currently there is no way to have the sign in account used to access the Collector be used against an On-Prem Server. If you are using Portal for ArcGIS you can federated your server with the Portal and that can leverage a single sign on. Another thing you could do is create a Feature Service item for the secured AGS service and embed credentials with that but that will only be able to leverage one account at a time.
Russ
AdrianMarsden
Honored Contributor
Cheers - at least I haven't missed something - realistically , at the moment, we are only having one editor out in the field.
So, what do I do now to your post - in the old form I'd mark it helpful - do I have to "like" it now !
NilsBabel
How do you check if ArcGIS Server service token security is enabled?  How do you enable it?  Russell Roberts
RussRoberts
In the server manager site you can enable security on your service by clicking on the lock symbol. The lock symbol will update from an unlock position to a locked position.
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
Russ
NilsBabel
Thanks for your reply,  I have the service secured.  But now my users have to log in a second time with an ArcGIS Server username.  Editor tracking works but the ArcGIS Server username is logged.  How can I get it to work with my users AGOL usernames?  Do I have to setup a role for each user?  How will this work in Collector?  Will they need to log in twice?
RussRoberts
Right now you will need to login twice. We do not share the AGOL credentials with the server because the server is not federated with AGOL. If you were using Portal for ArcGIS you can federate your server and that will bring a single sign on experience.
NilsBabel
What would happen inside collector?  Is their a prompt to login with their arcgis server username?
