Is there a way to open a map in Collector with a URL? Like Explorer for ArcGIS?
1977
02-10-2016 09:13 PM
DirkVandervoort
If I emailed the URLhttp://www.arcgis.com/home/mobileviewer/appsharer.html?id=ac7e0840c3444ccbb69082ad99d18eeb and the recipient had Explorer for ArcGIS installed on their device, tapping the URL would  open the web map in Explorer.
Is there a similar pattern where I can publish a web map that contains editable layer(s), then share a URLwhich includes the webmap id as a parameter, which will open Collector for ArcGIS when the link is tapped? If yes, what is the pattern for the URL?
TIA
