Hide web map for Collector For ArcGIS
5854
8
05-04-2016 06:48 AM
AndrewCallison
Is there away to to hide web maps from the Collector that are not meant to be used with collector?
Tags (3)
GISSupport3
For better or worse, Collector will only display maps shared with a group
PublicGardens
i dont think this is accurate!  because my web maps are displayed on the Collector , but nor shared with anyone !
GISSupport3
Odd ... can you please post a screen dump of the sharing window from the map details page?
PublicGardens
GISSupport3
Odder ... you got me there. No one (other than admins) should be able to see that map.
Something for your local Support to follow up.
Could try adding a group called HiddenMaps and then only have yourself in it.
Expected behaviour is must be in a group (and editbale) to be displayed in Collector.
PublicGardens
Thank you so much .. appreciate your help! i did nt know that admins will see all maps. i tried it from another user and the maps are not displayed in collector.
i need ur help in another issue concerning collector , if possible pls.
issue #1: i have a web map that i cannot take offline. i get an error when i "enable offline" : Wb map can not be taken offline ... bla bla
issue #2: i am not able to add a point on collector ( submit/ update) error: cannot update/ generate token..on IOS ONLY everything is working fine on Android device
i appreciate if u can guide me through this !
    THANK YOU
GISSupport3
Best to start two new questions on the forum ... not sure I'll have too much to offer and there are many others that will read.
PS I didn't think admins had special view powers either, though it worked out in the end.
PublicGardens
actually , i did post these questions before, but no one replied , anyway thank u so much
