editing attributes without editing the polygon
1810
06-16-2017 10:09 AM
deleted-user-gxWqNkvU_tDW
When setting up collector for field data collection I would like to be able to edit attributes in the configured popup window without the chance of editing the actual polygon shape of the feature.  Is this possible?  After all you can choose which attributes are displayed and edited but it seems to automatically allow the polygon to be changed.
PanGIS
Hi David, if your layer is hosted in AGOL try to set this in your Feature Layer (Hosted) Settings:
Thanks, Yes that does what i asked it to do.  However I still want to be about to add new or move points that also in the same file geodatabase.  I assume the solution then would be to create separate file geodatabases depending on my need to edit in the field.
