Downloading Attachments
6420
16
10-15-2013 11:54 AM
SarahO_Rourke
I want to use the collector app to collect attributes and photos for various structures. I have been able to create a feature service with attachments turned on, everything looks good with the app and the AGOL map but I can't seem to save the feature service back to my ArcGIS desktop version. I can open the feature service on the desktop and with 10.2 and can now see the attached images however I don't see a related table. I want to be able to see which pictures are attached to which point in an offline setting, is this possible?
Sarah
SarahO_Rourke
I still can't see the attachments, there is no related table in the local copy gdb. I don't know what I am missing.
I have looked at the other forums and it seems like I'm not the only one who has this problem.
CarynAshbay
Sarah, were you ever able to figure out the attachment issue?  I am having the same problem.  Cannot see attachments and there is no related data in the related table.
Thanks!
AidanMallamo
Thanks!
I am still having this problem on 10.2.1. I have a feature service that I created a while ago. The downloaded copy still does not contain attachments.
I need to republish to change the schema, but I cannot do so because I will lose all the attachments.
CarynAshbay
#1-You need to be running a Desktop Standard or Advanced license to work with attachments.  Not Basic.
#2-I finally got mine to successfully run when every feature had at least one attachment.  I had some features that did not have attachments and that bombed it out.
Hope that helps!
JessicaGooch1
Have you been able to figure this out???  I need to republish a HFS to change the schema and I also can't because I will lose all the attachments...I have some points that have photo attachments and some that do not.  Not all of my points need attachments.
Thanks!
-Jessica
RussRoberts
Esri Notable Contributor
I would recomend you posting this issue in the Desktop forum to see if they have a resolution for downloading the attachments from a hosted service. You can also try this python script which will pull down the features along with the attachments.
https://gist.github.com/oevans/6992139
Russ
NanettePratini
I have tried all of these solutions and am still having similar issues. I am able to create a local database that includes a table and a relate for the attachments, and in ArcMap I can view the attachments in a popup window just fine, but it looks like the attachments (photos) are still in the cloud somewhere.
I can see that a local copy of the photo is created in my /temp folder when I view it or right click on the filename, but that all goes away when ArcMap is closed. I want to be able to have everything local, including the attachments, to give to the client when the project is over.
