Collector Sync Error Unable to Synchronize Replica
5623
07-16-2014 06:52 PM
JeffreyLougee
Does anyone have any ideas on this error? This service has been working fine for the past few months and I've collected and synced hundreds of features. Could it have something to do with the new version of Collector? I recently updated to Collector 10.2.4 and I'm running iOS.
Tags (1)
EthanGomberg
I have the exact same issue. Did you ever find a solution?
DeniseKing
Hi Jeffrey,
Have you been able to resolve the Collector Sync errors you reported here? If not, please contact Esri Support and submit a Support case so that you can work with Support analyst to resolve this error and start using the Collector for ArcGIS app. Please mention you were directed to work with Esri Support from this GeoNet post.
Cheers,
Denise
Technical Lead - Apps/Mobile
JeffreyHolden
I have had these sync errors on occasion when the internet connection is poor.
Try to connect with a better WiFi or Cellular connection and try again.   It should work.
Jeffrey Holden
JeffreyHolden
I am getting this message now.   I have tried with a number of networks, and it still is not working.  I was testing this along with a number of other devices.   It worked well until I have tried to Sync the data and I got this error.
I need to get these points back.
Jeffrey Holden
SterlingLoetz5
We are having the same issue. Same error. Anyone find a fix for this?
