Collector - Read only feature service
1050
11-19-2016 10:22 AM
WellingtonChristian_Rodrigues_
Hi everybody
I have some troubles in my Portal, I will explain
I created a map that consume a feature service with all operation enabled, this map will be used for the field crew on inspecions in general. As part
of this map I have a Polygon feature class related (using relationship class Composite) with a simple table.
I would like to share the same map with a departiment (lets call Department_A).
So I Created a group in my Portal named Department_A and a new role using the visualization template in my Portal the role's name is Viewers.
Everybody that works on Department_A has a role named Viewers.
When a Shared my map with the group Department_A All users member of Department_A only can view the map and cannot apply edits through Portal Web Map. Works nice!
But when a user member of Department_A open the map through ArcGIS Collector, they can apply new edits and delete features, so, it doesnt works like on my Portal.
I thought I'm going to publish a new feature service on my ArcGIS Server, but a Read-only service just with Query and Sync capabilities enabled. I create the new web map with the read only feature service
but when try to access the web map using the ArcGIS Collector, the map doesn't appear. I can't see the map.
My environment is
ArcGIs Server 10.4.1
Portal 10.4.1
Oracle Database 12C
Can someone help me with this issue?
Am I doing something wrong?
Reards
Wellington
