I noticed recently that an iPhone and Android handle the date field differently.
Note: These date fields are the ones that were created for editor tracking.
Is there a way to change this? Where I can modify the time in this field like the android?
Anyone have any thoughts on this one? Why cant I adjust the time on an iPhone but I can with an Android?
Have you tried different formats when configuring the pop-up including your date / time field to see if all configurations are broken?
(^ in this window)
In practice, we've found that only the first two formats seem to support both date and time entry across all three versions of Collector: iOS, Windows, and Android. (If it's mentioned in the Collector documentation somewhere, then we've missed seeing it...)
Once you've picked one of those two formats (m/d/y or d/m/y), then you are able to tick the "Show time" checkbox. (That checkbox is hiding under the drop-down list of formats in Pete Crosier's screen shot above.) You should see something like this in your Configure Attributes window after you select the row with your field, and select one of those formats:
And, checking the box, it becomes...
Now you should be able to pick a date and time in Collector on your iPhone.
I know this is a stupid question...but where are you setting this? AGO?
Wait think I got it....testing
I have just done a test webmap
The same map works with Date Time on Android Collector however on IOS only Date
Will log the call and move from there
