Using the latest Collector with an R2 CM Edition receiver. Seems to work great, but I'm concerned about the accuracy reporting. I've lost my connection to my base station a couple times which reduces the accuracy of this receiver from 1 cm to a couple of meters, but Collector does not give me any indication that there is a problem and just lets me continue collecting data. It continues to report that I am getting less than an inch of accuracy when that is not the case. Has anyone else seen this issue? I'm going to do more extensive testing to reproduce the issue before I submit a case, but I wanted to see if anyone else has seen this and resolved it already?
Andrew,
I think if you look at NMEA output from GeoXH, probably it doesn't report GST sentence, which is required for accuracy report. If no GST is reported, Collector will do some rough estimate. You can find more info at
GPS receiver support—Collector for ArcGIS | ArcGIS
-Morgan
Do you know of an easy way to write out a sample of the NMEA output to see if GST is reported?
Any new testing results to report...? thanks!
