Hi
I have set up my map and collector to track locations in the field but after doing a couple of tests this does not seem to be working. I used the below guide. Track where collectors went—Collector for ArcGIS | ArcGIS. Am I doing something wrong?
The layer is turned off in the app by default. You can enable the layer under the contents button if you want to see it in the app. The app will drop a point on the set interval of the location tracking layer with the editor tracking info.
I Have enabled the layer on the app but when I tested it out it did not automatically place points when out in the field.
Can you share the map and service with Collector4ArcGIS and I can take a look to see if there are any issues.
