can't collect data on shared map
2315
7
02-03-2016 08:31 AM
AudreyWagner
I'm new to Collector.  I've followed the tutorial and shared a map to a group of two.  We can both see the map via Collector, but only the author can use it to collect points.  What is the missing link?
Audrey
JakeSkinner
Esri Esteemed Contributor
Hi Audrey,
What is the Role of the other user?  They may be assigned to an ArcGIS Online Role that does not have Edit privileges.
AudreyWagner
We are both publishers in the same group.  We each have created a map that we have shared to the group.  We can collect data on our own maps, but not on each others'.  The other's map is visible, but there is no + icon, and we cannot turn on or off the other's map layers in Collector.
Might this be a setting at the group level?  Or some error in how we are sharing?
Thanks for helping
AudreyWagner
Is it better to do this via email?
Thanks for helping
Audrey
-AW
Lecturer
Southern Illinois University Carbondale
Department of Geography and Environmental Resources
1000 Faner Drive Room 4534 Mailcode 4514
Carbondale, IL 62901
Office (618)453-6031
JakeSkinner
Can either of you edit each other's web map in the ArcGIS Online viewer?
AudreyWagner
When I open her maps in the online viewer (via pc), it opens, then gives me a series of error messages saying the various layers cannot be added to the map (the "collector" layers, and the tracking layer). This leaves only the base map.
From the details page, these are the contents she put in the map.
Map Contents carbondale tracking:https://services6.arcgis.com/qtHZoRrWRCQ8eh1J/arcgis/rest/services/carbondale_tracking/FeatureServer/0
Test - Type of tree:https://services6.arcgis.com/qtHZoRrWRCQ8eh1J/arcgis/rest/services/Test/FeatureServer/0
Test - Bike Stations:https://services6.arcgis.com/qtHZoRrWRCQ8eh1J/arcgis/rest/services/Test/FeatureServer/1
Test - Condition of Light Posts:https://services6.arcgis.com/qtHZoRrWRCQ8eh1J/arcgis/rest/services/Test/FeatureServer/2
Topographic:https://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer
She's not here at the moment to try mine, but will be able to try later.
I have an email in to our administrator, but he is not super Arc-savvy... we are at a university
Audrey
-AW
Lecturer
JakeSkinner
Most likely the feature layers are not shared with the Group.  Make sure the web map and all associated feature layers are shared with the Group you are a part of.
AudreyWagner
Ok, I had originally shared it from Arc Desktop. Just now I re-shared it from the ArcOnline viewer, and she is able to access the editable layers. I'm not sure what I did wrong via the Desktop share, but will have to look into it later.
Thanks for your help!
Audrey
-AW
Lecturer
