One common web map for online and offline scenarios with Collector
303
02-20-2020 05:08 AM
Status: Open
MichaelGabel
New Contributor II
As soon as an offline area has been created on the basis of a webmap with Collector, this map is no longer available on Collector for online scenarios. From this point in time, this map can only be used as a source for creating additional offline map areas. It is no longer possible to use this webmap directly in online mode. It would be desirable that a web map is optionally available for online scenarios and, if necessary, can be used as a source for offline map areas. For this reason, two separate webmaps must currently be available on the collector to map the use cases online and offline. This causes additional effort in the creation and maintenance of the additionally required web map (s).
