NTRIP in ArcMap /Collector
2053
04-26-2017 05:35 AM
Status: Open
IngenieurbueroBulle
Moin Moin,
es wäre super, wenn es zukünftig eine Möglichkeit gibt, die die Verwendung von Korrekturdaten ermöglicht.Z. B. bei Collector die Option zur direkten Verbindung mit einem  NTRIP-Server, sodass exakte Koordinaten mit dem Collector erfasst werden können.
Google translation: It would be great if there is a possibility in the future that allows the use of correction data. Eg for Collector, the option for direct connection to an NTRIP server, so that exact coordinates can be recorded with the Collector.
Tags (1)
2 Comments
RobertNagy
Hey! I am having the same issue, but i am using a third party sofware to send corrected GPS signals, via mock location in Android. The GPS receiver i am using is TOPCON, but support is found also for Leica. If you are interested i can describe how i worked around the issue.
ChrisJensen
Robert,
I was using a Topcon Hiper SR with Arcpad and eGPS on a windows 7 device.  How are you getting your receiver to use Collector?  I would like to use it on Windows 10 or an Ipad.
