Disable Attachment Sync by map layer instead of by map
2613
02-22-2021 03:55 PM
Status: Open
MarcusKlatt1
Disable attachment synching for offline use on tablets and phones on a by layer basis instead of by map.
This will allow in a single map to have one layer with fewer attachments toggled to download attachments for offline use while toggling another to not download attachments.
For example, on a large and long term survey, initial nest location photos are collected.  Then construction activities are documented on a separate layer with multiple photos daily.  The documentation photos may add thousands of photos which will eventually slow down the download or max out the tablet storage capacity.  It would be great to be able to have a single map that could house both these datasets.
2 Comments
CraigMueller1
I agree, and really support this idea. To add another user story: I have multiple layers with attachments enabled and my field staff will take data offline in areas where there may be extensive photos and PDFs attached with pre-existing data. Most attachments aren't necessary to do the work in field and are only relevant in-office, but depending on the work sometimes they may need attachments for a particular layer. For instance, when doing inspections of construction work they may want as-built photos, or when doing bio surveys they may want to view previous attached survey PDFs, but the non-relevant attachments in other layers cause the map area download size to get out of control. The Field Maps web app seems like the perfect place and opportunity to allow for turning on and off attachments per layer.
TimothySeaman
This would be huge for me. I have data collection points with a ton of photos, which need to sync up for future use in the office, but are not used again in the field. Meanwhile I have other layers where attachments are used multiple times in the field. With everything syncing up and down, it quickly adds up to multi GB download areas. So I need to allow certain layers to sync attachments up and down, but other layers up only.
I would imagine this setting would fit nicely on a webmap page at Settings>Offline>Options>Features and attachments
Hopefully this idea is still in the mix, and hasn't fallen away because it appears to be in a Collector folder.
