Collector: Multiple Basemaps for Offline Use
3921
06-11-2015 09:17 AM
Status: Open
NicholasMcNamara
In disconnected (offline) mode, you can currently only have a single basemap. Currently, you can add additional basemaps as layers as a workaround, with the layer unchecked and the user can check it to turn it on. However, this is a sloppy work flow that would better be executed by utilizing the basemap switcher in Collector. In offline mode, the basemap currently has no use. Instead of loading the additional basemaps (aerials or basemaps) you have into a layer, it should be possible to add them in as secondary basemaps that could be accessed via the basemap switcher. In this way, Collector in offline mode would operate as online mode, but you could access local maps instead of ArcGIS Online maps. Also, if you were online and could access online maps, you should be able to add more than one of your local basemaps.
2 Comments
IngaPlayle
I have loaded two tile package basemaps (.tpk) files to my iPad via cable/iTunes. I can then access these as basemaps in offline mode and switch between them using the basemaps icon. Is this what you are wanting to do?
Natalie_MRunyan1
in our workflow, this would require a prohibitive amount of manual oversight to generate the various extents and scales that different users need (because their devices are limited in storage capacity) and then to maintain the TPK files on the filesystem.  This is why I want the user be able to select multiple basemaps according to their own extent and scale parameters.
