Is there a way to view the edges of a published 3ws file. Attached is a side by side comparison of what I see in the cityengine viewer and the 3ws web viewer. The cityengine model has edges visible while the 3ws online one doesn't have the edges on. Is it possible to enable viewing edges in the 3ws web viewer?
Thanks.
Unfortunately no. But you can publish as an SLPK and you can add edges in a scene.
You could also modify your rule to create outlines...with an offset. It can get complicated but its doable.
