Using Point Shapes for asset placement
4324
05-04-2015 12:14 PM
DerekSpencer
Hello,
I am still learning .cga scripting, and I've found the tutorials pretty useful for mass modeling, but I can't seem to find any references for using point data for asset placement.
I have an area in my map where no footprint data is available, but a .shp of points is available. I also have a library of around 50 residential buildings (.obj).
I would like to use this shapefile data to randomly distribute residential buildings.
Ideally, I'd like to ensure that they are rotated to face the street, but as of right now I can't seem to bring them in in the first place.
Here is what I have currently:
attr
elevation= 0
attr Residential("assets/Buildings/Residential/Residential_*.obj")
@Start
Lot -->
     i(geometry.area(rand(10,30)))=ResidentialBuilding
ResidentialBuilding -->
     alignScopeToAxes(y)
     i(assetBestSize(RESIDENTIAL))
I have tried other variations on this, including removing the lot completely (I don't need it- I just thought maybe my asset import needed an area to compare Scope with)
But no matter what I do, I seem to always get the same Mismatched Token error with my i() function.
I am sure there is a simple way to use point features for asset placement. How do I make this work?
Thank you.
by Anonymous User
Not applicable
Here's a start:
BuildableSpace -->
     innerRect
     alignScopeToAxes(y)
     i(assetBestSize("assets/Buildings/Residential/Residential_*.obj","xz"))
See if that gets anywhere.
DerekSpencer
Hi Chris,
Thanks for the help. innerRect bases size on a lot shape, though. I am trying to place assets with point data because I do not have footprint or lot shapes to use for procedural generation.
Using this script I'm no longer receiving any errors, but when I Generate, nothing is placed.
by Anonymous User
Not applicable
How about:
attr testAsset = "assets/Buildings/Residential.___seeBelow____.obj"
# So the testAsset should be set to a file name, not a wildcard.
# And to test this, we print to console to make sure we have a proper asset.
BuildingInsertionPoint -->
     # Scale to a point, since in CE all points are tiny squares. This inserts in model's units.
     s(0,0,0)
     print(fileExists(testAsset))
     i(testAsset)
# Let me know if this brings one of your assets into the scene.
