Texturing sidewalks at Junctions properly
1843
11-29-2012 02:04 AM
ElliotHartley
A quick question, I've got a streetnetwork where the sidewalk is split into different surfaces, to reflect for example, paved and planted areas.   The trouble is at corners these sidewalks don't look right (I've attached a screenshot below).   Is there a way of making these textures turn the corner properly?  If so, can someone give me a code snippet?
Thanks!
[ATTACH=CONFIG]19599[/ATTACH]
MatthiasBuehler1
Hi !
Since the Shapes come from the 'Dynamic City Layouts' system, this is not possibly automatted with CGA.
You'd have to create a rule which does those splits based on attributes which are manually set.
That is a limitation ..
M.
ElliotHartley
Thanks anyway... looks like I still need SketchUp for some parts.... Feature Request? 🙂
MatthiasBuehler1
That'd be a part of a rework of the Dynamic City Layouts, yes.
May take some time though ..
