Terrain or Texture map layer Image Size Limit
1226
02-06-2013 03:00 PM
JenniferPollom
Does anyone know if there is a limit to the size of an image that can be used for the Terrain Texture map layer?  I have higher resolution imagery that I would like to use, but the application never resolves to add the Terrain layer when I use the high res imagery.
MatthiasBuehler1
JenniferPollom
Thank you.
