SubdivideShapesSettings - setLotSubdivisionMethod
2911
11-14-2011 05:37 AM
Jackde_Valpine
I am working on a python script that subdivides blocks (imported) based on some different parameters. To set the parameters I am using the SubdivideShapeSettings methods. Some of these class methods do not appear to exist, such as setLotSubdivisionMethod? Following is the function that I have defined:
[INDENT]def subdBlock(name):
    subds = SubdivideShapesSettings()
#    subds.setCornerAlignment('STREET_LENGTH')
    subds.setCornerAngleMax(90.0)
    subds.setCornerWidth(0.0)
    subds.setForceStreetAccess(0.0)
    subds.setIrregularity(0.3)
    subds.setLotAreaMax(1500.0)
    subds.setLotAreaMin(500.0)
    subds.setLotElevation("EVEN_MIN")
    subds.setLotMinWidth(10.0)
    subds.setSubdivisionRecursive("True")
    subds.setOffsetWidth(25.0)
#    subds.setSeed(0)
#    subds.setShallowLotFrac(1.0)
#    subds.setSimplify(4.0)
#    subds.setLotSubdivisionMethod("OFFSET")
    ce.subdivideShapes(name, subds)[/INDENT]
The commented items generate errors when I try to include them.
I am running CityEngine 2010.3 build 0124 (release, win32-64bit).
-Jack de Valpine
PS, Note I have tried to see if this has been addressed in the forum archives. However, I am relatively new to City Engine, so if this is FAQ or otherwise documented somewhere please point me in the right direction!
Tags (3)
AndreasUlmer
not fully sure what you mean by
"The commented items generate errors when I try to include them."
does that mean when executing the script, or even before?
The script you sent parses fine for me. One thing that could be unclear:
you are calling the subdivide function with the param name.
how does your function call look like? are you calling subdBlock(name) with name being a string name (e.g. "MyShape")? That would not work. You need to put a list of shapes as parameter.
So I recommend to rename
to
def subdBlock(shapes):
  ce.subdivideShapes(shapes, subds)
and calling it for example with
shapes = ce.selection()[0]  ## the first object in the selection
subdBlock(shapes)
assuming you have a shape selected.
Jackde_Valpine
Hi Andreas,
Thanks for the follow-up!
The argument <name> that is being passed to the function is a shape.
The issue that I noticed is that several of the shape settings do not seem to work/exist, eg setCornerAlignment, setSeed, setShallowLotFrac, setSimplify, setLotSubdivisionMethod. These class methods are all listed in the on-line documentation so it is puzzling. I did discover that there is a method: setSubdivisionOffset which is really what I thought I wanted out of setLotSubdivisionMethod. So I do have a scripted block subdivision working (note this is for static imported block shapes).
-Jack
BenLeslie1
I too am having difficulty defining the subdivide settings using Python.  I'm attempting to do a select by attribute followed by a subdivide - similarly to Jack de Valpine the code works with some subDivide settings defined, but when I add other settings (such as setSimplify) the code does not work.  Does it matter what order settings are defined?
Here's my code - I must say I've only really worked with arcpy before and I'm finding this code a little alien:
def selectByAttribute(attr, value):
    objects = ce.getObjectsFrom(ce.scene)
    selection = []
    for o in objects:
          attrvalue = ce.getAttribute(o, attr)
          if attrvalue == value:
              selection.append(o)
    ce.setSelection(selection)
selectByAttribute("buildCat", "Residential")
shapes = ce.getObjectsFrom(ce.selection())
divset = SubdivideShapesSettings()
divset.setLotAreaMin(200)
#divset.setIrregularity(0)
#divset.setSimplify(1)
#divset.setLotSubdivisionMethod("SKELETON")
ce.subdivideShapes(shapes, divset)
