Split a block in a "controled" way
3594
10
11-23-2014 02:16 AM
aTomasaLooström
I would like to control the splits blocks created when I creates streets, not using type under Block Parameters.
In some cases a block needs to be split in half, with the same area, and in some cases the blocks needs to be split in trees parts, and so on.
Is there a way to control this?
And if there are can some one show me the code to do that? I am still learning and have a looong way left:)
Best regards Tomas
Tags (1)
MatthiasBuehler
Just use the split() operation ..
Did you work through tutorial 6 ? This explains the basics of CGA.
Matthias Buehler
Head of 3D Technologies
twitter: @MattB3D
Garsdale Design Limited
matthias.buehler@garsdaledesign.co.uk
www.garsdaledesign.co.uk
