silent installation issues
3011
03-13-2012 02:11 AM
ardblenke
I would like to install the CityEngine silently in our classroom. Starting with the /S command line option will run the silent install but the installation of vcredist_x64_vc10 is not started properly from the main installer. It still needs user input, it looks like the wrong command line options have been used to trigger this installation. If this vcredist_x64_vc10 was already installed then the installer will start in repair mode.
It would be even better to hava an MSI installer.
Ard
MatthiasBuehler1
hi.
there's no msi installer available. Hope you make it happen with the exe installer too..
ardblenke
Fortunatly cityengine folder can simply be copied to another computer. Works fine if you have the vc redistributables installed.
Please do fix the incorrect vcredist installation in the next version (or make a msi).
Ard
