import objet.
4510
6
03-26-2012 11:02 AM
BENOITBastien
Bonjour, j'ai créer le circuit et tout va bien mais le problème je voulais savoir si c'était possible de importé un objet dont c'est un arbre, et je veux mettre plusieurs arbre automatiquement est-ce possible ?
Hello, I create the circuit and everything is fine but the problem I wanted to know if it was possible to import an object that it is a tree, and I want to put multiple tree automatically is this possible?
MatthiasBuehler1
hi !
yes, this is possible !
the easiest way to do this is to use the 'scatter' operation (check the CGA docs in the F1 Help Menu).
next to this, you can also use the split() operation to split e.g. a plane in the 2 dimensions into smaller shapes on which you insert assets.
let me know if this helps you further...
[I guess you'd like an example, right ? 😉 ]
matt
BENOITBastien
Yes, please.
MatthiasBuehler1
here's 3 ways to do this ..
[ see attached project ]
let me know if you have questions ..
BENOITBastien
Thank you. 🙂
BENOITBastien
Bonjour, j'ai copier le fichier cga, pour les plantes ca va, mais j'ai fais une route en faite les grillages ne suivent pas la route et je veux les coller et que ça suivent.
Hello, I copy the file cga, for plants it's going, but I'm a road made �??�??fences do not follow the road and I want to stick them and follow it.
google translate.
BENOITBastien
It's good, I found. ^^
