setting startRule when using PyPRT
1365
08-01-2023 10:15 AM
Mateo_Neira
I'm trying to create OBJ's using the python bindings for the procedural runtime. I have 4 shapes and I want different shapes to be generated using different rules defined in my CGA - I would normally do this by setting the startRule as an attribute of the shape.
It seems that pyprt does not support setting a StartRule file anymore? this used to be a parameter that could be set for each shape.
as an example I have:
Using the pyprt I've tried to use the shape attributes for this:
shape_attributes = [
    {'shapeName': 'left_lot', 'seed': seed, "startRule": "Lots"},
    {'shapeName': 'left_sidewalk', 'seed': seed, "startRule": "Sidewalks"},
    {'shapeName': 'street', 'seed': seed, "startRule": "Street"},
    {'shapeName': 'right_sidewalk', 'seed': seed, "startRule": "Sidewalks"},
    {'shapeName': 'right_lot', 'seed': seed, "startRule": "Lots"}
#prt_shapes is a list containing 5 pyprt shapes
model_generator = pyprt.ModelGenerator(prt_shapes)
#my rpk with the different rules which I want to use as startRules
rpk = os.path.join(cwd, 'model.rpk')
encoder = 'com.esri.prt.codecs.OBJEncoder'
encoder_options = {
        'meshGranularity': 'AS_GENERATED',
        'vertexNormals': 'SET_ALL',
        'baseName': "street",
        'outputPath': cwd
generated_models = model_generator.generate_model(
        shape_attributes,
        rpk,
        encoder,
        encoder_options
 When I run this, all models are generated using the default StartRule defined in my CGA rather than the one specified by the shape parameters.
SimonHaegler
Hi Mateo,
we removed support for explicitly setting the start rule in PyPRT 1.1 (2020), there were some problematic edge-cases (styles) and we aimed for simplicity.
How about introducing a "dispatcher" start rule which calls the desired rule based on an (enum) attribute? If you do not want to modify your existing "model" rule you could put the dispatcher into a separate rule file and use import.
Best,
Simon
Mateo_Neira
Hi Simon,
I did end up doing a similar approach to a dispatcher rule and that's all working. Thanks for the suggestion.
Best,
Mateo
