Setback (possible) Bug
1454
11-26-2011 06:47 AM
AndréCardoso
I don't know if I should post these findings here... please correct me, or move this to a more appropriate section...
While moving a project to the 2011 version, I had multiple CE crashes while trying to generate geometry. The crash was related to a 'setback' operation. I had something like this:
HouseSetBack -->
 setback(gardenSetback){
  remainder : innerRect House |
  all: NIL
The mere opening of the CGA rule file containing this, would crash CE, because of the default preview bar of the rule (I reckon it evaluates the code, thus crashing)....
If started through a terminal, CE outputs the following:
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00007f6112ff80a3, pid=13790, tid=140054875539200
# JRE version: 6.0_26-b03
# Java VM: Java HotSpot(TM) 64-Bit Server VM (20.1-b02 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C  [libcom_procedural_grammarcore.so+0x29f0a3]  SetbackOperation::FaceSetback::extractSetbackFaces(std::vector<unsigned, std::allocator<unsigned> > const&, Mesh const*)+0x671
How to solve? Well, I merely changed the code to the following, reversing the selector's order:
HouseSetBack -->
                all: NIL |
Which, probably, is the way it is meant to be used... I'm a little confuse now... anyway I think it's not supposed to crash CE !
Can anyone confirm this?
Using Ubuntu Linux 64 bits, CityEngine 2011 64 bit.
Hope this helps,
André
MatthiasBuehler1
hi Andre.
can you check if the issue is that the scope is not yUp ?
before the setback operation, try alignScopeToAxes(y).
is it this ? please let me know.
matt
MatthiasBuehler1
by the way, setback and the shapeLOU operations need a yUp scope.
as you certainly know, after a comp(f), the scope is zUp.
AndréCardoso
I've just tried what you said. But no luck. Also, the setback was one of the first rules on the footprint, so the scope must've been yUp already (correct me please) !
The test done was (now with the first rule of the footprint):
Lot -->
 90%:
  HouseSetBack
  Garden
 else:
  innerRect
  House
HouseSetBack -->
 alignScopeToAxes(y)
  remainder: innerRect House |
  all: NIL
And again on the terminal:
Don't know if it helps (did not open it), but in the attachments follows the error log generated.
André
hi Andre.
matt
