Selected Extent Too Small for Get Map Data- CityEngine
5646
12
01-04-2017 10:48 AM
DavidWasserman
I keep getting this error while trying to get map data. I am not sure what I am doing incorrectly. I do this because there is a known bug in 2016.1 where you can't map to layer attributes without a raster image of some type in the scene or a layer that has an attribute whose named is shared with the rule*(See Cheryl's comment below).
I can get it to work at a very low resolution when zoomed out, but the same is not possible when zoomed in. Is there any guidance between the relationship between the resolution or extent for this feature?
Any ideas?
Relevant documentation page: Get map data from ArcGIS Online / Portal
David Wasserman, AICP
ThomasFuchs
The default values are not optimal when you have an empty scene with no coordinate set.
In this case just lower the basemap resolution (High -> Med) or increase the width/height of the bounds (1000 -> 2000). Both has the same effect.
nazaninyousefi
You must change the resolution option on the custom
DavidWasserman
That was not the issue in this case I think. I think it has to do with the Tile requirements Thomas mentioned. When I tried custom, it gave a similar response.
